Old 04-12-2021, 10:16:19 AM   #1
bkk2004
Arrow ___ ขายสายอากาศเทพ Diamond CP6 HF Multi-Band : 3.5 / 7 / 14 / 21 / 28-29 / 50MHz ราคาถูก
ขายสายอากาศ Diamond CP6 HF Multi-Band : 3.5 / 7 / 14 / 21 / 28-29 / 50MHz ราคาถูก
ของใหม่ 16,xxx ฿ -- >> https://www.strictlyham.com.au/diamo...6#.YaNOGLinp9Y
ต้นนี้ ใช้งานไม่ถึงปี สภาพปกติ ไม่เคยล้มไม่มีอะไรบิดเบี้ยว อุปกรณ์ครบทุกชิ้นยกกล่อง ขาย 8900 ฿ พร้อมส่ง ฟรีทั่วไทย
( ประหยัด 8,xxx ฿ )
สนใจโทร 0869455977
หรือ Line ID: ctek.thai
CP6 : 3.5/7/14/21/28/50MHz(80m/40m/20m/15m/10m/6m)29MHzFM
Length:4.6m / Radial length:approx.1.8m / Weight:4.9kg
Max.power rating:200W(SSB) / Impedance:50ohms / VSWR:Less than 1.5:1
Rated wind velocity:40m/sec. / Mast diameter accepted:30mm to 62mm
Connector: SO239 female UHF / Type: Self support 6 band trapped vertical antenna with trapped radials.Radial elements can be set for one direction.
Diamond CP6 ( HF Multi-Band Vertical Antenna )
Specification:
Model: CP6
Frequency Band: 6 / 10 / 15 / 20 / 40 / 80 m
3,5 / 3,7 / 7 / 14 / 21 / 28 / 50 Mhz
Gain: Unity
Type: Compact Vertical
Description:
The CP6 multi-band trap-vertical antenna for HF bands, covering the 80*, 40*, 20, 15, 10 and 6m amateur bands.
Made from heavy duty aluminum, the CP6A assembles easily, yeilds excellent performance and reliability from a compact base station antenna.
Its compact size allows for many mounting options. Minimum 15' diameter required for mounting radials. No additional ground radials required.
Special Features:
• Compact size
• Heavy-duty aluminum antenna sections
• Easy assembly
• No additional ground radials required
• Mounting hardware included
Specifications:
Frequency: 75 - 40 - 20 - 15 - 10 - 6m
Power: 200 watts PEP
Impedance (output): 50 ohms
VSWR: 1.8:1 (Nominal)
Element Phasing: 1/4 wave trap vertical groundplane.
Radials: Six, Trap design.
Grounding: Direct grounding. Antenna element and radials connedted to mounting pipe.
Max Wind Rating: 80 mph (no ice)
Mast Diameter Acceptance: 1.2" - 2.4"
Overall Length: 15.1' (4.6m)
Weight: 9.9 lbs. (4.9kg)
bkk2004 is offline   Reply With Quote
Old 04-12-2021, 10:17:05 AM   #2
bkk2004
Arrow
รูปเพิ่มครับ โพสใด้แค่ครั้งละ10รูป
