ขอถามรายละเอียดเครื่องหน่อยครับ
jirawut777
ขอรายละเอียดของเครื่อง 220,230,240 หน่อยได้ไหมครับ....
230E M102 1985-1992, L4 2298 cc, 8 Valves, 95.5x80.25, 136 HP/5100 rpm, 205 Nm/3500 rpm, Compression Ratio 9:1, KE-Jetronic Fuel Injection System
220E, E220 M111 1992-1994, L4 DOHC 2199 cc, 16 Valves, 89.9x86.6, 150 HP/5500 rpm, 210 Nm/4000 rpm, Compression Ratio 10:1, HFM Fuel Injection System with Camshaft Adjuster (Intake Only)
280E, E280 M104 1992-1994, L6 DOHC 2799 cc, 24 Valves, 89.9x73.5, 193 HP/5500 rpm, 270 Nm/3750 rpm, Compression Ratio 10:1, HFM Fuel Injection System with Camshaft Adjuster (Intake Only)
320E, E320 M104 1992-1994, L6 DOHC 3199 cc, 24 Valves, 89.9x84, 220 HP/5500 rpm, 310 Nm/3750 rpm, Compression Ratio 10:1, HFM Fuel Injection System with Camshaft Adjuster (Intake Only)
C240 W202, E240 W210 M112(1) 1998-2002, V6 SOHC 2397 cc, 18 Vavles, 170 HP/ 5900 rpm, 225 Nm/ 3000-5000 rpm, Twin Plugs, 5-Speed One-Touch Gearshift
C240 W203, E240 W211 M112(2) 2002-, V6 DOHC 2597 cc, 18 Vavles, 89.9x68.2, 177 HP/ 5700 rpm, 240 Nm/ 4500 rpm, Compression Ratio 10.5:1, Twin Plugs, 5-Speed One-Touch Gearshift
